Test on Canbus communication
08/17/2015 at 20:39 • 0 commentsIt's just preliminary, but data streams are coming out ready to process. Video to output
Recieve parts and assemble
08/17/2015 at 20:36 • 0 commentsImported Library's and first code assembled. Headers soldered on to Canbus shield, hopefully all will work when plugged in! Pictures wouldn't upload, procrastination for uploading is a killer!
Ordered Parts from Sparkfun
08/17/2015 at 20:32 • 0 commentsAfter much research, settled on a board easily sourced from a trusted supplier; Picked up a couple of other things as well :)
Concept and Reasearch
08/17/2015 at 20:27 • 0 commentsCan-bus can be a little daunting, especially considering the proprietary definitions used in the manufactures systems. The vehicles mechanical systems have their own setup as well. I found on my particular vehicle the user gas pedal contained two potentiometers biased differently, so in order to emulate the pedals behavior with a digital pot it would require biasing with resistors in addition to the digital potentiometers.
