11Step 11
Use the ribbon cable to connect the motors and the laser diver module. Use whats most suitable for you. I connected the ribbon cable to a pcb where I connected 4 wires from the y-axis. Then I used smaller ribbon cable to connect the laser driver.
12Step 12
Attach the end switches.
13Step 13
Attach the Laser, the laser driver the flat ribbon cable to the middle plate.
Jack Pearse
