SDCard Info
01/31/2017 at 18:20 • 0 commentsI've compiled SDCard Info example with the updated OLED Display Library and it works fin, jut do't forhet to switch SS between the display and SDCard. Here is a sample code:
const int chipSelect = 23; DIP_OLED oled; char s[20]; void switch_sd_ss(void) { //Select CS output to SD Card DDRB |= (1 << 4) | (1 << 5); PORTB |= (1 << 4); PORTB &= ~(1 << 5); delay(2); } void out_text(int x, int y, const char * str) { oled.out_text(x, y, str); oled.display(); switch_sd_ss(); } void setup() { oled.init(); oled.clear(); out_text(12, 10, "SD Card Test"); ...![]()
Updated DIP OLED library
01/30/2017 at 14:45 • 0 commentsI am updating DIPDuino libraries and making it compatible with Arduino 1.8.0 IDE
Here is DIPDuino OLED library packaged for Arduino IDE: dip_oled.zip
... and some sample code:
#include <dip_oled.h> DIP_OLED oled; void setup() { oled.init(); oled.display(); }If everything is good , you'll get this result:
Update pin-outs diagram for Arduino IDE
01/19/2017 at 18:16 • 0 comments![]()
DIPDuino driving two 64x32 RGB panels
01/18/2017 at 22:32 • 0 commentsHere is DIPDuino driving two 64x32 RGB panels over HUB interface. I am getting so much help from DIPDuino when building my prototypes.
DIPDuinos available now
05/03/2016 at 13:31 • 0 comments![]()
I 've made a small batch of DIPDuinos for sale. You can buy your own DIPDuino for $69.95 USD. Quantity is very limited. Please write me a message if you are interested. Your help and support is very appreciated!
DIPDuino - Humidity and Temperature Data Logger
02/08/2016 at 19:06 • 0 commentsSimple Humidity and Temperature data logger implemented with DIPDuino and DHT11 senor.
Both, temperature and humidity logged to SD card. There is no RTC yet, so no time-stamps.
Next step is to implement data transmission over ZigBee.
DIPDuino+Radar Transceiver
10/13/2015 at 02:26 • 0 commentsDIPDuino+Radar Transceiver = Radar Gun + Logger
Using DIPDuino in my research project:
OLED Library and New Body
09/10/2015 at 01:13 • 0 commentsWork is completed on OLED library for DIPDuino (dip_oled.h). Library is now available for download at DIPDuino.com.
Also, I've redesigned DIPDuino's body. Body version 2 snaps on PCB while previous version must be glued. At the same time I made couple of adjustments for better fit:
DIPDuino Revision 2
09/04/2015 at 02:23 • 0 commentsNew version of DIPDuino has four more ADCs inputs. New schematics is available on DIPDuino.com website and new pinouts diagram is published above. New PCB and Ardunino headers will be ready in few days.
DIPDuino's Schematics (version 2)
08/31/2015 at 21:01 • 0 commentsUpdated DIPDuino's Schematics (version 2) is available for download at DIPDuino.com:
Updated pin-outs and Arduino headers coming soon.
