Hackaday.io Hackaday.io
Sign up Log in
Touch Activated Blinky Badge
A touch sensitive two LED flasher badge for teaching soldering/electronics.
mahesh-venkitachalamMahesh Venkitachalam
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
278
4
6
11
Team (1)
  • mahesh-venkitachalamMahesh Venkitachalam
Join this project's team
ongoing project
led badge touch blinky
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 08/30/2015 and last updated 11 years ago.
Description
I wanted to create a simple project to teach soldering and electronics to kids (10+ years) and beginners. I first thought of a simple two transistor LED flasher, but then decided to make it interactive by adding a touch sensitive element to it. The idea is that once made, this PCB can be worn as a badge.
I had initially designed this using through-hole components. But with SMD becoming more and more common, it seems like a better choice. Plus SMD will have a much flatter profile - more suited to a badge.
I plan to test this out with my 10-year old first. If that goes well, I plan to organize a soldering workshop in my neighborhood.
Here is the github repo for the project:
https://github.com/electronut/blinky-badge
Project Logs
Collapse
  • Fixed timing
    Mahesh Venkitachalam • 09/24/2015 at 03:43 • 0 comments
    It was a chipped 47K resistor I damaged during soldering. Works nicely now.
  • It works!
    Mahesh Venkitachalam • 09/23/2015 at 16:50 • 0 comments
    Magnifier lamp broken, so pretty much soldered it blind. It works, but timing seems a bit off. ;-)
  • Just got the first PCBs!
    Mahesh Venkitachalam • 09/23/2015 at 11:37 • 0 comments
  • Ready for first PCB
    Mahesh Venkitachalam • 09/04/2015 at 10:37 • 0 comments
    Almost ready to send off to the PCB man...
  • Touch Plate
    Mahesh Venkitachalam • 09/01/2015 at 08:43 • 0 comments
    Done with custom footprint...
  • Touch Plate footprint & Python
    Mahesh Venkitachalam • 09/01/2015 at 04:30 • 0 comments
    Creating the kicad touch plate footprint with some help from Python...
  • Designing PCB
    Mahesh Venkitachalam • 08/30/2015 at 10:02 • 0 comments
    Tested on breadboard. Now working on PCB design with kicad.
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
Sandeep Patil wrote 09/02/2015 at 05:26 • point
the painting is neat!
Mahesh Venkitachalam wrote 09/02/2015 at 05:28 • point
Thanks!
davedarko wrote 08/30/2015 at 09:24 • point
please post some pics of the results :)
Mahesh Venkitachalam wrote 08/30/2015 at 10:00 • point
I will, thanks!
Last year, our customers made impressive Christmas PCB ornament. And part of the projects are opensource.
Project Owner Contributor
How to Design Unique Christmas PCB Ornament
elecrowElecrow
This is a 8x8 WS2812b NeoPixel LED matrix that is completely flat surface and has the same 1.6mm height as a normal PCB
World's Slimmest NeoPixel LED Matrix
sayantan-palSAYANTAN PAL
A practical guide to PCB art with Inkscape and KiCAD
Making a SAO with Inkscape and KiCAD
danielDaniel
The challenge building a miniature cube is to make it easy to solder. There are only 4 connections per face, 12 edges, how many wires?
RGB miniature cube
nicoud-jean-danielnicoud jean-daniel
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Touch Activated Blinky Badge", please tell us the reason.
Send message
Remove Member
