Replaced broken links with local pics
07/24/2020 at 08:59 • 0 commentsReplaced the broken links to the discontinued tinypic.com with local pics uploads.
What does that moving magenta signal represent?
09/19/2015 at 01:21 • 0 comments![]()
In the animated image, the blue sinus represent an analog input signal of 440 Hz, and the magenta moving sinus represent the multiplied output of the circuit. The digital multiplication factor is dictated by the Arduino program, and it varies in time from -1 to +1. Because the multiplication factor varies, the magenta output also varies, and that is how the animated picture was produced.
RoGeorge
