This is what should and did happen.
04/28/2014 at 23:26 • 1 commenthttp://youtu.be/m72xytB71K8
Trouble with Editting this Project is NOT Why it FAILED.
04/28/2014 at 22:26 • 0 commentsSo, the instructions did not load properly. But that does not change the results of FAILURE. To show you how it failed I am editing a video. Stay tuned.
The Face of Zardoz
04/27/2014 at 21:20 • 0 commentsAs was mentioned in the parts section, the ZARDOZ head was someone else's creation. Please look at there write up (http://godzillu.daa.jp/zardoz/). I can only say their work was impressive.
So followed the instructions and built a ZARDOZ face.
Start # 1
04/27/2014 at 21:08 • 0 commentsSo, the first issue is making it fly. To that end, a few mods to a quad-copter were undertaken. An under-frame was attached to allow a frame to be created for applying a skin outside of the propeller range.
cabrera.101
