Frame:
3030 and 3015 series from 8020. This is 3" x 3" extruded aluminum, and 3" x 1.5" extruded aluminum. The frame is bolted together using standard 8020 hardware and joining plates.
Motors:
280 OzIn 8-Wire Stepper Motors from Probotix, 1.8 degree, 200 steps per revolution, 3 Amp Current Per Phase, Nema 23, Dual Shaft.
Motor Drivers:
ProboStep VX. Microstepping chopper current driver.
jupdyke
Will F.
charliex
Greg Duckworth
Stefan Lochbrunner
I did not know that the CNC mills machine is built like this because I never happened to see a video like this about it. I have got masterpapers online for help in essays online. I am glad that you shared this article and enhanced my knowledge about it.
