1BUILD
Build the circuit as shown in the diagram.
![fritzing_preview.png]()
2Program
- Download the project file here
- Extract the contents of the files.
![1.JPG]()
- Open the project file for the Arduino codes.
- Upload the Arduino code to your board
- Open the project using Workshop 4. This project uses the Visi Environment.
- You can modify the properties of each widget with the object inspector.
FOR A DETAILED INSTRUCTIONS PLEASE GO TO THIS LINK
- Click on the “Compile” button. Note: This step could be skipped. However, compiling is essential for debugging purposes.
- Connect the display to the PC. Make sure that you are connected to the right port. Red Button indicates that the device is not connected, Blue Button indicates that the device is connected to the right port.
- Go back to “Home” tab. This time, click on the “Comp’nLoad” button.
- Workshop 4 IDE will prompt you to select a drive to copy the image files to a uSD Card. After selecting the correct drive, click OK.
3Hardware Assembly
With the given circuit above, you can design your own prototype in accordance to your preference. Here's one example.
![DSC_0179.jpg]()
![DSC_0041.JPG]()
4D Makers
