So far, I have decided on almost everything that I want so far. I am going to use 2 MAX8 Hobbywing ESCs for the speed controllers, 2 5065 270kv brushless outrunner motor for the motors, 12 ANR26650 LiFePo4 Batteries, and an Arduino Pro Mini knockoff for the main control board of the longboard. For the remote, there is yet another Arduino Pro Mini, powered by a LiPo 750mAh 3.7v battery. To save power, the regulator on the board will be disabled because the chip can accept voltages from 2.7v-6.3v. There will be a LiPo charger onboard so it is not necessary to open the shell and remove the battery. The controller shell will look like this:
dylxnxil
Sophi Kravitz
matthewhallberg
RachelAnne
this is really amazing and unique project about . i cannot see any project like this before. great work keep it up. i am also working on a coffee site . click here to check out.https://coffeeccinos.com/best-automatic-pour-over-coffee-makers/
