Print done
A project log for RGB 16 Segment LED
one does not simply order 50 ws2812b LEDs and has a 3D printer at home
davedarkodavedarko 09/29/2015 at 06:281 Comment
Black plastic was by choice, I was afraid of color bleeding, if I print in white. I added a coat of primer spray and will later spray it white for highest reflectance. Not sure about the toplayer yet. Might print something with z-glass from zortrax finally.
Rich text editor
davedarko wrote 09/29/2015 at 08:33 point
Importing svgs into 123D Design was a bit tricky, I had to resize the object to pixels matching millimeters.
