RGB 16 Segment LED
one does not simply order 50 ws2812b LEDs and has a 3D printer at home
I saw rgb 7 segment displays once, it was beautiful.
it's 80x100mm
23 leds means buy 100 get 4 digits - nice!
characters.h
h - 6.14 kB - 05/01/2017 at 10:00
Download
Segment16_ws2812.ino
ino - 1008.00 bytes - 05/01/2017 at 10:00
Download
16seg.stl
Standard Tesselated Geometry - 376.10 kB - 05/01/2017 at 09:58
Download
16seg.123dx
123dx - 187.77 kB - 05/01/2017 at 09:58
Download
16-Segment-LED_final_normal.svg
svg+xml - 5.07 kB - 05/01/2017 at 09:57
Preview
  • weird
    davedarko • 11/06/2015 at 23:00 • 1 comment
    My ascii 'little a' is 98, according to my array. Not sure why. But here we have: text! Finally - before I was running the demo script from adafruit.io, that surely looked nice.
  • Backside
    davedarko • 10/04/2015 at 15:51 • 2 comments
    as requested by @Stefan-Xp
  • supply power
    davedarko • 10/01/2015 at 19:47 • 3 comments
    I wanted to power my arduino and the wsb2812bs from the same source when running, but didn't want to kill my usb port when programming, so I used some diodes from a rectifier.
  • Print done
    davedarko • 09/29/2015 at 06:28 • 1 comment
    Black plastic was by choice, I was afraid of color bleeding, if I print in white. I added a coat of primer spray and will later spray it white for highest reflectance. Not sure about the toplayer yet. Might print something with z-glass from zortrax finally.
View all 4 project logs
Maksim Surguy wrote 06/07/2017 at 17:43 • point
Great project! I have a similar one but only for 7 segment. Did you write software for Arduino or Raspberry Pi?
I'm thinking of building a similar display with APA102 2020 size... Should be a fun journey!
davedarko wrote 06/07/2017 at 18:21 • point
Hey Maksim, thanks! The software runs on an Arduino, but with wiringpi it should run on a pi as well.
Sounds like a cool project, those 2020s look very nice!
AVR wrote 04/26/2017 at 20:56 • point
I have a bunch of these, regular sized that i need to do something with, pretty sure they are red, I got an entire tube of them.
Mike Szczys wrote 04/24/2017 at 22:20 • point
Wow, this really came out great. Kudos Dave!
davedarko wrote 04/25/2017 at 10:19 • point
Hehe thanks Mike :)
Elliot Williams wrote 04/26/2017 at 20:25 • point
Mike, you have to see them in real life!
Jan wrote 03/05/2017 at 15:13 • point
Damn fine project! I thought my upcoming 60x30mm RGB 7 segment would be unique, but yours looks amazing.
How much space is between the LEDs and the front? As I've got no 3D printer I am building my version with laser-cutted parts.
davedarko wrote 03/05/2017 at 15:23 • point
Yay, thanks! it can't be much more than a centimeter (checked, it is). The display itself is 10x8 cm2.
davedarko wrote 03/05/2017 at 15:24 • point
if you have to decide because between 3mm and 4mm and between 8 and 12  resulting in 9 or 12mm, take twelve.
Elliot Williams wrote 10/05/2015 at 19:05 • point
Saw this in real life.  The paint job works perfectly as a reflector. It is beautiful!
Stefan-Xp wrote 10/04/2015 at 15:15 • point
Nice Progress!
But i really wonder how the Back of the Digit looks after you soldered it ;)
davedarko wrote 10/04/2015 at 15:38 • point
ahh, you want to see the dirty details, don't you? I wanted to have something to show on saturday, so I rushed the prototype :)
jaromir.sukuba wrote 10/01/2015 at 13:39 • point
Now let's make equivalent of 16x2 character LCD made of those displays!
davedarko wrote 10/01/2015 at 19:47 • point
that's gonna be slightly pricey :D
Stefan Lochbrunner wrote 10/02/2015 at 17:11 • point
I second that idea! Come on Dave, you know you want to ;)
deʃhipu wrote 09/29/2015 at 08:01 • point
Hmm... you could display whole words by having each letter a different color, and blending them... I wonder if you could "scroll" them by moving each of them through the hue...
Stefan-Xp wrote 09/28/2015 at 22:57 • point
Great Project! ;-)
As long as it glows, its my thing ;)
davedarko wrote 09/29/2015 at 06:30 • point
Oh it will :3 in so many colors that anyone would only ask "Why?"
But I still don't get the usefullness :D really makes no sense.
alpha_ninja wrote 10/01/2015 at 14:05 • point
Who said things one makes have to be useful?
