it's 80x100mm
23 leds means buy 100 get 4 digits - nice!
one does not simply order 50 ws2812b LEDs and has a 3D printer at home
it's 80x100mm
characters.hh - 6.14 kB - 05/01/2017 at 10:00 |
Segment16_ws2812.inoino - 1008.00 bytes - 05/01/2017 at 10:00 |
16seg.stlStandard Tesselated Geometry - 376.10 kB - 05/01/2017 at 09:58 |
16seg.123dx123dx - 187.77 kB - 05/01/2017 at 09:58 |
16-Segment-LED_final_normal.svgsvg+xml - 5.07 kB - 05/01/2017 at 09:57 |
My ascii 'little a' is 98, according to my array. Not sure why. But here we have: text! Finally - before I was running the demo script from adafruit.io, that surely looked nice.
as requested by @Stefan-Xp
Black plastic was by choice, I was afraid of color bleeding, if I print in white. I added a coat of primer spray and will later spray it white for highest reflectance. Not sure about the toplayer yet. Might print something with z-glass from zortrax finally.
Hey Maksim, thanks! The software runs on an Arduino, but with wiringpi it should run on a pi as well.
Sounds like a cool project, those 2020s look very nice!
I have a bunch of these, regular sized that i need to do something with, pretty sure they are red, I got an entire tube of them.
Damn fine project! I thought my upcoming 60x30mm RGB 7 segment would be unique, but yours looks amazing.
How much space is between the LEDs and the front? As I've got no 3D printer I am building my version with laser-cutted parts.
Yay, thanks! it can't be much more than a centimeter (checked, it is). The display itself is 10x8 cm2.
if you have to decide because between 3mm and 4mm and between 8 and 12 resulting in 9 or 12mm, take twelve.
Saw this in real life. The paint job works perfectly as a reflector. It is beautiful!
Nice Progress!
But i really wonder how the Back of the Digit looks after you soldered it ;)
ahh, you want to see the dirty details, don't you? I wanted to have something to show on saturday, so I rushed the prototype :)
Now let's make equivalent of 16x2 character LCD made of those displays!
I second that idea! Come on Dave, you know you want to ;)
Hmm... you could display whole words by having each letter a different color, and blending them... I wonder if you could "scroll" them by moving each of them through the hue...
Oh it will :3 in so many colors that anyone would only ask "Why?"
But I still don't get the usefullness :D really makes no sense.
Great project! I have a similar one but only for 7 segment. Did you write software for Arduino or Raspberry Pi?
I'm thinking of building a similar display with APA102 2020 size... Should be a fun journey!
