weird
11/06/2015 at 23:00 • 1 commentMy ascii 'little a' is 98, according to my array. Not sure why. But here we have: text! Finally - before I was running the demo script from adafruit.io, that surely looked nice.
Backside
10/04/2015 at 15:51 • 2 commentsas requested by @Stefan-Xp
supply power
10/01/2015 at 19:47 • 3 commentsI wanted to power my arduino and the wsb2812bs from the same source when running, but didn't want to kill my usb port when programming, so I used some diodes from a rectifier.
Print done
09/29/2015 at 06:28 • 1 commentBlack plastic was by choice, I was afraid of color bleeding, if I print in white. I added a coat of primer spray and will later spray it white for highest reflectance. Not sure about the toplayer yet. Might print something with z-glass from zortrax finally.
davedarko
