Black plastic was by choice, I was afraid of color bleeding, if I print in white. I added a coat of primer spray and will later spray it white for highest reflectance. Not sure about the toplayer yet. Might print something with z-glass from zortrax finally.
davedarko
Importing svgs into 123D Design was a bit tricky, I had to resize the object to pixels matching millimeters.
