Ion wind loudspeaker experiments
Ion wind lifters make wind (airflow). Make that wind variable => sound ;-)
The idea came to me a little bit after I saw an ion wind lifters (small things that can fly when high voltage is fed into them). Anther thing of inspiration was a device called rotary woofer, which is a fan with blade pitch being changed by electrical signal, that is able to emit very low frequency sound.
Compared to rotary woofer, ion wind speaker should perform well not just at super-low frequencies, but all the way up into ultrasound. This makes an interesting possibility to build an extremely wideband speaker. So the project started.
Although I invented the concept from scratch, I wasn't the first one to do it. But at the time, I was unable to find any info on that on the net, so I well and truly thought I invented a new concept. As usual, it was busted some time later.
This project is an overview of my experimentation with making ion wind speakers, and is going to point to numerous sub-projects involved in making it.
==Background
First up, a few links to existing stuff on the subject.
Air Speaker - A website devoted to massless loudspeakers
Stable sound wave generation in weakly ionized air medium (scientific article)
EFA Loudspeakers - they claim their loudspeakers can make 130 dB SPL, corresponding to sound pressure of 60 Pa. I doubt it, because it means at least 1.2 kg of thrust due to constant wind (HUUUGE).
Ion wind sound emitter is made of two major pieces: a blower, and a high-voltage-output power amplifier, which requires a high-voltage power supply.
==System components (sub-projects)
Blower
The blower is the essence of the project, which is just some metal and some insulator parts put together to generate ion wind when high voltage is applied
#IW blower theory. Some calculations of ion drift zone, the region where the actual wind is created.
#IW blower 1 - the first blower that was able to make some sound.
#IW blower 2 - pipe - the most successful one so far. It is a wire stretched in a half-pipe-shaped other electrode.
#IW blower 3 - multistage - attempt of multistage, multielectrode blower.
#IW blower 4 - 3d printing test - testing compatibility of ion wind and 3d-printed stuff.
High-voltage power supply
At the beginning, I was using a CRT-transformer based high-voltage power supply, with a bunch of capacitors and a string of standard 1kV 1A diodes used as zener shunt voltage regulator.
Later, I've built a long diode-capacitor voltage multiplier, which is silent, and generates a large sequence of high voltage potentials (positive and negative, up to +/- 20 kV / 40 kV between extremes). Having a sequence of potentials (including negative) is very handy for multi-electrode experiments.
High-voltage audio amplifier
Again, I had two generations here. One was just a microwave oven transformer connected to output of a regular audio amplifier. I won't even bother documenting it, but it was good enough for proof-of-concept experiments.
#IW High-voltage amplifier
It is based on a high-voltage vacuum tube, and has an optional feedback for getting voltage-drive output. Vacuum tube was chosen not because of audiophile reasons, but rather due to the tubes being extremely tolerant to high-voltage abuse. A single spark can easily kill a transistor, yet to kill the tube, one has to supply substantial power for substantial time to melt the anode, which is plain impossible with my power supplies.
#High-voltage oscilloscope probe is an essential part of the feedback circuit of the amplifier.
==High-voltage safety
Voltages in this project can reach 40 kV. This much voltage stored in some substantial capacitance like I have in my high-voltage power supply, can potentially cause death.
I recommend reading this: http://www.instructables.com/id/Work-safely-with-high-voltage/
Here are some rules that I'm trying to follow when doing this.
1. Make sure the low-voltage part doesn't charge up to high-voltage potential, by ensuring it is earthed. Make sure it is safe to operate the on-off switch.
2. Make sure the operator (you, me) is NOT earthed. This should limit the zap you get if you accidently touch the point at high potential.
Don't wear an antistatic wristband, as the 1M resistor in it is not a high-voltage resistor. It can be broken down when you get the zap, effectively directly earthing you.
3. Operate the thing with one hand only when it is powered up. Again, this should limit the zap in case you get one, to just the hand, with almost no current passing through heart zone.
View all 2 project logs
adrian wrote 12/08/2022 at 20:11 • point
This is a great modern project similar to early work on ion speakers and plasma speakers  on https://massless.info (the new version of the airspeaker.co.uk website mentioned). From the 1950's Dr. Tombs developed a corona wind speaker https://massless.info/Tombs.html
DeepSOIC wrote 12/03/2017 at 11:59 • point
Just by accident, I googled out a PDF with very similar stuff, written in 2016. It doesn't look like it's an article in a journal, althoughit is written like one. I'm not quite sure what it is. It's in German.
http://studylibde.com/doc/13238014/-concept-and-prototype-of-an-ion-wind-speaker--1
They use similar geometry, same vac tube in amplifier, same opamp IC. My project is in their references.
davedarko wrote 12/03/2017 at 14:14 • point
looks like a publication for a convention, if that's a thing
Clara Hobbs wrote 12/03/2017 at 15:22 • point
From Wikipedia:
The biennial Tonmeistertagung[6] (VDT International convention) combines an international scientific conference and workshop program with a trade fair, focusing on applied research and technical excellence.[7] It has been in existence since 1949.[8] Similarly the International Tonmeister Symposium, dedicated to one thematic complex, is analogous to the AES-conferences.
For that kind of convention, it's most definitely a thing. 🙂
hubidrei wrote 11/21/2015 at 23:07 • point
I like plasma speakers especially plasma tweeters. On this page you can find a few descriptions of diy and professinal plasma tweeters maybe it is interesting for you http://www.plasmatweeter.de/contens_plasma.htm  sorry, its in german.
