The project must haves' are as follows.
DONE : *Fits in an area of 1 inch x 1 inch or (25.4mm x 25.4mm) Numitron Tube size: 32 x 10 mm (1.28 inch x 0.4 inch)
PROBABLY NOT : *Also compatible with HP bubble displays (4 digit 7 segment).
DONE : *at least 2 user buttons.
DONE : *an RTC DS1337
DONE MOSTLY (8Mhz) : *low power management running at 4~8Mhz
DONE (ATMEGA168) : *Atmel atmega line micro (looking at Attiny841 Micro).
DONE : *Serial interface.
DONE : *USB chargeable Libpo
DONE (300mF) : *Super cap backup for RTC.
Suggested features?
*N/A
Paste applied and getting ready to stuff parts.The front of the board holds the main micro an Atmega168 an 8bit shift register the DS1337 RTC user buttons and programming interface.
zaphod
alnwlsn
Colin Catlin
Shree Kumar
I couldn't find any design files—could you upload them by 23:59 UTC on Dec 8, 2015?
