From generic toner cartidge HP1102W printer, 346°F transfer temp - 10z copper , double sided - 1.6mm FR1 PCB.
JPEG Image -
1.38 MB -
02/29/2016 at 05:13
Preview
Using a Krazy glue cap 'punch'
JPEG Image -
1.70 MB -
02/29/2016 at 05:13
Preview
Used the Proxxon Press for this - 0.8mm bit.
JPEG Image -
940.44 kB -
02/29/2016 at 05:15
Preview
Nice surface finish to grip toner.
JPEG Image -
1008.13 kB -
02/29/2016 at 05:14
Preview
Isopropyl alcohol wipes (70 to 99%) with a good paper towel is fine.
JPEG Image -
1.06 MB -
02/29/2016 at 05:14
Preview
Bobby pin used to 'punch' registration holes in toner transfer paper to align with the holes in the copper.
JPEG Image -
1.42 MB -
02/29/2016 at 05:13
Preview
Bobby pins and painters tape
JPEG Image -
914.89 kB -
02/29/2016 at 05:13
Preview
Bobby Pin registration into the drilled copper PCB registration holes and painters tape.
JPEG Image -
980.61 kB -
02/29/2016 at 05:13
Preview
JPEG Image -
905.81 kB -
02/29/2016 at 05:13
Preview
Final registration step.
JPEG Image -
835.74 kB -
02/29/2016 at 05:14
Preview
8a-Toner-Transfer-laminator.mp4
Apache AL13P with my multi pass mod ( see other Hackaday project) running a double sided 'toner transfer' board in 1 pass.
MPEG-4 Video -
38.95 MB -
02/29/2016 at 05:40
Download
8b-Toner on Copper.mp4
Finished the laminator toner transfer. took 2 -3 minutes with the single pass made up of micro passes as seen in the Toner transfer video.
MPEG-4 Video -
12.89 MB -
02/29/2016 at 05:22
Download
Post transfer...look at the video (item 8)
JPEG Image -
1.06 MB -
02/29/2016 at 05:14
Preview
Layer 2 transferred along with layer 1
JPEG Image -
1.13 MB -
02/29/2016 at 05:14
Preview
9c Foil-transfer.mp4
Doesn't have to be micro passes, 2 normal 'full speed' passes would do the job.
MPEG-4 Video -
36.65 MB -
02/29/2016 at 05:34
Download
9d Remove-foil.mp4
Easy as that!
MPEG-4 Video -
30.75 MB -
02/29/2016 at 05:32
Download
Note videos on foil transfer using the laminator and peeling it off.
JPEG Image -
1.89 MB -
02/29/2016 at 05:16
Preview
JPEG Image -
1.82 MB -
02/29/2016 at 05:16
Preview
Results after about 12 minutes in dilute nitric acid. Probably the 10th use of the acid mix. You can handle the board with your fingers for a minute or so....no risk, it is so harmless to skin. No staining, no burning etc.
JPEG Image -
948.00 kB -
02/29/2016 at 05:16
Preview
JPEG Image -
977.76 kB -
02/29/2016 at 05:16
Preview
VISE MOUNTED ON DRILL PRESS SLIDE BAR, SHOWING 6-32 SCREW ADJUSTMENT FOR LOCK DOWN.
JPEG Image -
2.22 MB -
02/27/2016 at 19:39
Preview
BACK LIGHT SHINING THRU FR4, 1/16" PCB...THE ACTUAL VIEW IS MUCH CLEARER THAN THE PIC!
JPEG Image -
1.53 MB -
02/27/2016 at 19:39
Preview
BOTTOM VIEW OF MINI VISE STABILIZER SCREW MOD. 6-32 X 1.5". IT LOCKS THE VISE ONTO THE DRILL PRESS SLIDE BAR FOR 3 DIMENSIONAL STABILITY.
JPEG Image -
1.81 MB -
02/27/2016 at 19:39
Preview
