Hackaday.io Hackaday.io
Sign up Log in
quadcopter in one inch
itsy-bitsy teeny-weeny fully autonomous quadcopter
jeffjeff
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
21.6k views
20 comments
178 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 6
    • View all
  • Instructions 0
  • Discussion 20
View Gallery
21.6k
20
178
99
Team (1)
  • jeffjeff
Join this project's team
  • minicopter
  • oshpark
  • shapeways
hardware
ongoing project
Quadcopter one-inch much small! fly away! STM32 IMU flying machine look--up-in-the-air openscad one square inch os/j5 spinning blades of death
Related lists
Square Inch Project Entrants
Projects that fit in a square inch
Projects using OSHpark boards
projects using the purple PCBs
This project was created on 10/05/2015 and last updated 11 years ago.
Description
one inch flying machine
10 DOF IMU, motor drivers, and 32bit ARM CPU.
Components
  • 1 × stm32f411 ceu6 cpu
  • 1 × lsm6ds3 imu
  • 1 × lps25hb pressure sensor
  • 1 × lis3mdl magnetometer
  • 2 × drv8839 motor driver
View all 6 components
Project Logs
Collapse
  • FAA registration?
    jeff • 12/15/2015 at 02:44 • 0 comments
    fully assembled with battery, the device weighs 23.5 grams.
    making it exempt from the FAA's new registration requirements.
  • oops...
    jeff • 11/13/2015 at 05:36 • 1 comment
    I have a feeling this project will require a lot of ceiling paint...
  • test flight
    jeff • 11/13/2015 at 05:36 • 3 comments
  • assembly underway
    jeff • 10/29/2015 at 04:39 • 0 comments
    parts received. assembly underway.
  • 3D rendering
    jeff • 10/06/2015 at 23:53 • 0 comments
  • plastic frame
    jeff • 10/06/2015 at 02:59 • 1 comment
    plastic frame http://shpws.me/KjFl
View all 6 project logs
Log In/Sign up to comment
Sign up with Github
OR
EngineerAllen wrote 02/16/2017 at 12:11 • point
when you design your own flight controller with an ARM 32bit MCU how do you make the firmware and software? isn't that more difficult or do you copy opensource information
thanks
alexbhandari wrote 04/14/2016 at 00:36 • point
It looks like the board is three layers. There is a single trace on the middle layer. Was space so tight that you needed an extra layer just for that trace?
jeff wrote 04/14/2016 at 16:20 • point
it is actually 4 layers. the layers without traces are ground and vcc.
any component that needs to connect to gnd or vcc has a short trace on the top layer to a via which connects to it to the gnd or vcc plane.
Will Rea wrote 12/27/2015 at 12:22 • point
What motors are you using?
jeff wrote 12/27/2015 at 18:21 • point
hobbyking "0716". replacement parts for some sort of quad that they no longer sell.
x-labz wrote 12/23/2015 at 19:28 • point
Hey Jeff,
how can you control, give orders to the copter?
jeff wrote 12/25/2015 at 05:08 • point
I don't give it orders.
it is autonomous, it crashes into things of its own free-will.
x-labz wrote 12/25/2015 at 15:23 • point
cool :)
...but do You plan to add some short of senses to this poor little blind copter? infrared or UH?
...or by adding propeller cover/protector, it could survive the bumps, and even the CPU could recognize this collisions by analyzing the IMU data
anyway good luck with the project!
jeff wrote 12/25/2015 at 21:11 • point
I've used IR on other robotics projects, and wanted to here. the microcontroller has plenty of unused pins, but no room in one inch. next version, perhaps.
it is easy to detect bumps+crashes with the accelerometer, but I don't have a recovery algorithm better than "turn off motors", yet.
alpha_ninja wrote 12/07/2015 at 00:32 • point
[verified: no design files missing]
guybthe wrote 12/05/2015 at 18:46 • point
I know the goal is to do a 1 inch project, however would your control board work w/ larger scale drone / props / motors assuming more energy storage and step up for the larger motors? Very interested in this as a lightweight controller.
jeff wrote 12/06/2015 at 21:40 • point
the motor drivers won't handle too much more, they'd need to be beefed up,
and possibly the voltage regulator, if you want a higher voltage.
but the rest of the ckt should be fine.
alpha_ninja wrote 12/02/2015 at 00:46 • point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
Albert Latham wrote 11/09/2015 at 21:38 • point
Could you do a short post on the PCB, code, and other things involved in flight control?
jeff wrote 11/10/2015 at 01:12 • point
I just updated the github with the schematic, board, and cad files. I'm still working on the code.
did you have questions?
Albert Latham wrote 11/10/2015 at 01:22 • point
I saw that the control board has an STM chip which made me immediately think of Paparazzi. Is your code Paparazzi based?
jeff wrote 11/10/2015 at 04:48 • point
no, not based on anything
Albert Latham wrote 11/10/2015 at 04:58 • point
Look into Paparazzi. The code is very mature and is compatible with your main processor. You could potentially save a lot of development time by using it. (I'm biased as I worked with a system that was Paparazzi driven.)
Ivoah wrote 10/09/2015 at 00:32 • point
Why are the rotors tilted inwards? Does it help with stability?
jeff wrote 10/09/2015 at 19:03 • point
yes,  it improves the stability.   google the word "dihedral", if you are interested.
(but disclaimer:  I am not an aeronautical engineer)
A automatic facetracking mobilephonestand for videocalls, with manual control possibility
Project Owner Contributor
Face Tracking Mobilephone Turret
honxenhonxen
A robotic rover builds with spare part from hoverboards.
Not so small rover
tanguyTanguy
A full scale BB8 Astromech droid with deployable quadcopter arms in the shell.
3D Printed BB8 Quadcopter
dryerziniaDrYerzinia
This prototype is a simple horizontal wind turbines with innovative new turbines. Just 3d print it and tell us your own impressions!!
HORIZONTAL 3D PRINTED WIND TURBINE 15-20 WATTS
esposcar90esposcar90
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "quadcopter in one inch", please tell us the reason.
Send message
Remove Member
