3D Print Files.zip
An upload of the 3D print STL file for the first waterfall diagram generated that had interesting results. This also contains an excel file with the raw data.
x-zip-compressed -
40.63 MB -
01/30/2019 at 10:31
Download
Final Post Selection for Upload.zip
This contains a 3 minute RAW .WAV audio recording along with the "interesting" high-pass filtered "sound" of the grid that is featured up the top in the youtube video. Also included are the results (jpg) from the matlab run. Basically, this is the last set of results obtained before I finished this project. I'd just upload everything, but there is a 50MB limit per file upload...
x-zip-compressed -
29.89 MB -
01/12/2019 at 09:23
Download
Hottest Day on Record.zip
This contains the images from my project log on the hottest day ever in Adelaide. Unfortunately, it's only the images as the data is way beyond the 50MB size limit. Still, it's always nice to have them collected here and not lost in the endless log list.
x-zip-compressed -
2.95 MB -
01/28/2019 at 01:50
Download
WaterFall Era Pics Selection.zip
Selection of some JPGs of MATLAB plots, along with two actual plots in the MATLAB figure format. I'd like to just upload everything, but the waterfall plots are making these figures huge and that's just not possible any more. From now on it'll just by JPGs.
x-zip-compressed -
38.32 MB -
01/10/2019 at 11:03
Download
MATLAB Scripts.zip
The MATLAB code used to acquire data. Configuration is made in "main" and "sample grabber". Realistically, don't expect it to work with different sample rates, etc. without modification. Or just don't expect it to work at all. Run everything from "main". Written in MATLAB R2017a.
x-zip-compressed -
36.82 kB -
01/10/2019 at 10:46
Download
Results Images.zip
This is a collection of PNGs/JPGs of results and some other things - Check these out before the other results if you just want a feel for things.
x-zip-compressed -
1.60 MB -
01/01/2019 at 07:06
Download
Good Result.zip
Part 3/3: This is a "good" 16 hour results grab (no weird transients). This contains both a MATLAB figure (MATLAB 2017a) and a JPG image.
x-zip-compressed -
18.07 MB -
01/01/2019 at 06:13
Download
Results Set 1.zip
Part 2/3: More MATLAB figures of results (MATLAB 2017a). This is more of a results dump than anything cohesive.
x-zip-compressed -
45.76 MB -
01/01/2019 at 05:14
Download
Results Set 2.zip
Part 1/3: Some MATLAB figures of results (MATLAB 2017a). This is more of a results dump than anything cohesive.
x-zip-compressed -
34.39 MB -
01/01/2019 at 05:05
Download
Grid-2-Audio.pdf
A 3D PDF of the Grid-2-Audio PCB. Start here if you want a good look at the 3D model/layout. You'll need to download this and open it with Adobe outside of your web browser (probably). - This is the only 3D model uploaded that contains the additional "CF" capacitor across the final op-amp's feedback path.
Adobe Portable Document Format -
599.66 kB -
10/06/2018 at 12:07
Preview
Render Collection Upload.rar
A collection of my best renders from Fusion 360, along with the Fusion 360 file itself should anyone else care to indulge. The selection is somewhat limited due to the 50MB file limit.
RAR Archive -
48.96 MB -
09/27/2018 at 11:55
Download
Enclosure.rar
3D models of the parts of the device enclosure (Autodesk/STEP/STL). This now includes the revised main enclosure extrusion with additional ventilation and the fan cooling add-on.
RAR Archive -
4.36 MB -
11/03/2018 at 07:28
Download
PCB 3D Models.rar
3D models of the PCB design (Step, STL & PDF).
RAR Archive -
1.46 MB -
09/08/2018 at 03:57
Download
GerbersV3.rar
Gerber files for the design. Note that this rar can be directly uploaded to gerber viewers and previewed/manufactured. The top/bottom paste layers are not included (can be generated from the Altium files though). - Contains "CF" op-amp filter (i.e. latest).
RAR Archive -
40.34 kB -
10/06/2018 at 12:11
Download
BOM Grid-2-Audio.xlsx
A bill-of-materials list for the components to be loaded onto the PCB. "CF" is reflected here.
sheet -
11.81 kB -
10/06/2018 at 12:14
Download
Altium.rar
Design files for the entire schematic/layout. This is the latest version as it includes the "CF" capacitor to stop the opamp oscillating.
RAR Archive -
1.14 MB -
10/06/2018 at 12:25
Download
