This is one of the simplest Arduino compatible board. In a 18mm x 18mm sized board, it has only Atmega328 chip on the top side of the pcb while other side consists of 8 mHz crystal and AMS1117 voltage regualtor as well as with some capacitors and a resistor.
I can't find your design files, could you link to them?
