Good enough for now!
11/18/2015 at 01:52 • 0 commentsThe 3.3V logic from the NodeMCU wasn't enough to fully turn on my FET, so I have rigged up a simple level shifter using a diode and resistor. The light is actually fairly bright now rather than the dim glow it used to be.
gannon
