Port code over to Rust
07/09/2019 at 12:29 • 1 commentFairly recently I discovered the Rust programming language and fell in love with it! So much so that I decided to change the hardware to an STM32 microcontroller and rewrite the entire firmware in Rust. You can take a look at the code over here: https://github.com/SamP20/SelfBalanceSkateboard/tree/master/RustFirmware. The C firmware is still there if you're interested, however it's incomplete compared to the Rust version.
The Skateboard is now fully functional at last! Unfortunately however it's a bit unstable to ride in practice. The flexibility in the threaded rod is partially to blame, however the differential steering doesn't help much either as you have to remember to lean as you move the steering joystick otherwise you'll fall off. If I ever get time to rebuild this project I may opt for a single wheel design similar to the commercial OneWheel as it looks a lot more intuitive to ride.
Firmware code available
04/03/2016 at 22:55 • 0 commentsIn case you've missed it, the firmware for the microcontroller is now on GitHub: https://github.com/samp20/SelfBalanceSkateboard
As of this post there's no support for steering yet, however I have implemented a PD loop for balancing. I can't really do much testing at the moment anyway until I have a proper enclosure for the electronics. I'm going for a steampunk-ish theme, so stay tuned.
Motors have been installed
01/10/2016 at 21:41 • 0 commentsI have finally managed to get hold of a router to mill the slots for the motors. These should allow me to tension the chain as it becomes slack. Unfortunately one of the motors isn't quite aligned laterally causing the chain to catch occasionally. I should be able to fix by widening the slots by about 0.5mm. Here's a photo of the underside:
Once that's sorted I can finally start testing the balancing code. I'll also need an enclosure to protect all the electronics and battery.
It didn't break (yet)
12/03/2015 at 22:33 • 0 commentsI've got all the steel box section screwed down, and couldn't resist giving it a try. To my relief it didn't break!
The climbing shoes were because my feet kept slipping off the board when trying to get on (normal shoes would probably have worked too). I'll put some grip tape on the deck eventually which should sort that problem.
Reinforcement and axle bracket
11/28/2015 at 22:41 • 0 commentsSteel box section has arrived, so I've been spending time cutting it to length and drilling holes. I've decided to have one length down the middle to stop the deck from bending. Either side are brackets to hold the axle. Next step is to drill and countersink holes in the board to fix everything down.
Chains and bearings have arrived
11/16/2015 at 23:49 • 0 commentsOf course when new parts arrive you have to find some way of playing with them, even when you're still waiting on something else. Anyway, here's another video of me messing around:
Playing around with the motors
11/13/2015 at 23:58 • 0 commentsI decided to test out the serial interface of the Sabertooth motor controller while waiting for parts to arrive. The easiest way for me to test it was to use a USB<->serial adapter and create a quick script in python. All the script does is ramp the motors a few times, then oscillate them to a sin wave. Video below.
More purchases and testing
11/11/2015 at 19:45 • 0 commentsA little more progress has been made purchasing parts for the board. A trip to toolstation means I now have a 1m length of M12 threaded bar which will be cut to length for the axle. I've also purchased various nuts, bolts and washers to secure everything together.
Also I felt like doing a quick mockup to get a feel for what the final board will look like:
Finally I managed to do some more testing of the motor controller. I have now proven to myself that I can easily send commands to the motor controller from an Arduino via the UART (serial) interface. I'm not sure whether I will use an actual Arduino in the final version however. There is only one serial interface available which is connected to the the USB<->serial interface. Any serial commands sent from the PC will also arrive at the speed controller. I do have some bare ATmega328P microcontrollers lying around, so I might use one of those and program it via ICSP instead. Alternatively the speed controller has an emergency stop pin which, when pulled low, disables the motors.
Motor testing
11/09/2015 at 22:34 • 0 commentsA quick test of the motor controller. I had to be slow decelerating to avoid feeding too much power back into the power supply. This is an advantage when using a battery as it allows the battery to be charged during braking:
