Thoughts about microcontroller
03/15/2018 at 22:14 • 0 commentsI did a little bit of research which microcontroller I should use. Becuase using USB on an microcontroller is new to me it should be also well documented. And to fit this project It should be relative small.
First I thought about the Atmegegas with USB (32u4, 32u2...), which are still a backup possibility, bur so far i Will concentrate more on Microchip's PIC16F1454 . Resons for that are:
- The "MPLAB Xpress PIC16F18345" development board is using this PIC as USB interface.
- I do have one oft this boards. So I do have already hardware for first Tests
- On this board the programing interface of the PIC16F1454 is routed out on testpads
- One button is connected to IO of the PIC16F1454
- Two LEDs are connected to IOs of PIC16F1454
- This bord although made for evaluting the PIC16F18345, fits perfect my needs for testing, Just the PIC16F18345 needs to ignored
- Picture below shows this board
- Available at low price in huge number of different packages (including dip for prototyping or QFN for PCBs)
- There is an reference design by Microchip about bulding a keypad
- As alternative to Microchips USB-Stack (which looks like not being open) the free and open source USB stack "M-Stack" should run
Idea/Concept
03/12/2018 at 20:38 • 0 commentsInspired by the hashkey, but a more flexible diy opensource solution which could be built at home some key ideas:
- Cap and case 3D-printable (will publish files) on mostly every 3D-Printer
- Small PCB with all electric components including:
- USB Microcontroller (still not sure which)
- USB connector - exchange you wire to any color and length
- optional RGB LED for some colorful backlight
- Switch (perhaps a mechanical cherry-style one)
And here some sketch of it:
