1PCB assembly
Solder all components, specially BPW34 array and 433MHz transmitter
2Set AVR FUSES
avrdude -C ./avrdude.conf -v -p attiny85 -c usbasp -P usb -U lfuse:w:0x42:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m
BOD OFF, 1MHz, fast startup 0ms
3Programming
there is sample Manchester code firmware transmitter code
4Receiver
Use arduino UNO with 433MHz receiver to receive transmitted code, for debugging and transmission test, open power jumper and connect CR2032 battery to check transmission.
bobricius
