Transmission working !!!!!!!!!!!!!!!!!!!!!!!!
07/13/2018 at 22:40 • 0 commentsAfter hours/days of debugging and tuning I have working reliable transmission.
Some facts:
Transmission time for 16bit data with 1200bps is 34ms with all sync and receiver tuning bites
Harvester features:
Key timing component is middle capacitor, and there is some power facts
As load is connected Attiny85/1Mz with running code (no sleep) without transmitterPower supply length
- 100n = 15ms run-time every 1s
- 1uF = 17ms run time every 13s
- 10uF = 35ms every 60s
I have now reliable transmission for 16bit value every 30minutes, It is little long time but I am on beginning
with this project.Without load is power supply pulse 60ms long every 60s
Harvester demonstrator & test board half assembled
07/04/2018 at 22:31 • 0 commentsYes, finally boards are home. All working good :)
06/27/2018 at 21:52 • 0 commentsI finished harvester demonstrator with wireless transmitter and Attiny85
Solar array is large but I have plan to use only 4 diodes.
dirty run time check ... is 150uS enough ???
06/21/2018 at 21:36 • 0 commentsI try charge pump with attiny85 1Mhz
digitalWrite(LED,HIGH); delayMicroseconds(1); digitalWrite(LED,LOW); delayMicroseconds(150); // runtime delay digitalWrite(LED2,HIGH); delayMicroseconds(10); digitalWrite(LED2,LOW);
With dirty trial and error experiments I adjusted, maximum run time is 150uS with 1Hz repeating
Of course there is lot of possibilities to charge additional capacitor but unfortunately voltage rising very very slow and micro-controller can not start.
I think 150us is enough to send very short maybe 8bit packet with simple 433Mhz ASK/OOK radio
Success for 4 small diode power supply
It is time do design first more complex board :)
Prototype testing board
06/12/2018 at 20:32 • 0 commentsAfter breadboard success I designed first application .... flashing heart, first batch was just only garbage due mistake in design.
Harvesting test
06/12/2018 at 20:26 • 0 commentsAs you can see on first video, led flashing in room light.
Power output is short 2V pulse.
I created all on breadboard and about month experimentally adjust components values to get best performance.
Charge pump schematic.
bobricius
