I did some brainstorming about Number of Digits, Drivers, Microcontroller and Interface. I ended up with the following for the the first main board design:
- 5 Digits wich are connected as 25x7 Matrix (25 cathode columns and 7 anode rows)
- Driven by:
- two 16-Bit constant current low side drivers (MBI5026 or similar)
- one 8-Bit source Driver (probably MIC5891) in the same SPI bus
- OR one logic demux with p-fets or driver directly controlled by GPIOs
- One low cost 8-Bit MCU (probably some SMT8S)
- doing all the LED multiplexing
- UART and/or I"C as control Interface
- ESP8266 Module
- because everything needs wifi
- Maybe ESP8285 to safe some space
I hop all these ICs will fit on the back of 5 Digits. I will try this the next days.
Alex
