Custom Headers
11/10/2016 at 20:48 • 0 commentsI often need slightly customised headers or connectors for various purposes. In this instance I needed a surface mount 0.1" header footprint which I later replaced with the modified 8 pin through hole header. Lastly I needed a footprint for a terminal block that has 2 solder contacts but is only a single output. Interesting parts all in all.
A supplier example is here: Farnell
Eagle library (for 8 pin version) here: SMD Header
This is the footprint of the modified 2X4 0.1" header. This is to allow 4 inputs with a VCC and GND that is no wider than the 4 data pins themselves. I doubt this is a readily available product...
Eagle library: 2X4 Header Modded
Finally I want to be able to use screwless terminals in my projects. An example of a product that would fit into the footprint: Farnell
A neat little wire to PCB connector with a pitch of 2.54mm so as to keep everything compact.The footprint looks like this in Eagle:
The extents of the connector are also shown.Eagle library: Edge Wire Terminal
Thanks for looking.
SN74LV161 - 4-Bit Synchronous Counter
10/11/2016 at 22:32 • 0 commentsThis is a high speed counter that is able to circumvent the ripple effect in other more conventional counters (often known as ripple counters). This counter has a maximum input frequency of 230MHz and a propagation time of <4ns on all outputs. This is going to be the counter IC in a frequency counter project that I am currently working on.
Sadly there aren't any particularly interesting pictures of this IC so here is a link to the datasheet:
and here is a current dropbox link:
Please message me if the links do not work and I shall endeavor to get them back up quickly.
Greg
LM2596 Module Placeholder
01/21/2016 at 21:37 • 4 commentsThis is a place holder for the LM2596 Buck converter bought on eBay. Basically just an easy way to prototype in Eagle.
The set pin is the 'centre' tap of the pot and it means that I can control the voltage output of the module with an input voltage.
Datasheet is here:
My eagle library is here:
LT3080
01/21/2016 at 20:51 • 0 commentsThe LT3080 is a low dropout linear regulator. I will be using the big brother (the LT3081) in an upcoming project (Stay tuned for the LT3081 Eagle file and the project as well :D). I like this regulator as it is capable of true 0V output and has good noise performance.
Datasheet is here:
and my library for it is here:
https://www.dropbox.com/s/74zndz5tp7flgkd/GD_LT3080.lbr?dl=0
As always, Let me know if there is anything you good people want to see.
MCP4728 and MCP4725
11/30/2015 at 23:17 • 0 commentsThis is a 4 channel 12-bit digital to analogue chip. It has buffered outputs, non-volatile memory and latches to synchronise the output voltages. I am intending to use this on my PSU project and my electronic load project. It has an I2C interface making it ideal for fast interfacing with minimal pins required.
Datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/22187E.pdf
The Eagle library is available from the Farnell website as a script but is also here:
https://www.dropbox.com/s/qsf117s8xstmd1z/GD_MCP4728.lbr?dl=0
The MCP4725 is the single channel version.
Datasheet: http://www.farnell.com/datasheets/1470577.pdf
https://www.dropbox.com/s/3e9hgs6sxingyf3/GD_MCP4725.lbr?dl=0
TS1100
11/30/2015 at 21:30 • 0 commentsThis is the Eagle library for the TS1100 current sense amplifier.
Data sheet: http://www.farnell.com/datasheets/1774455.pdf
This is going to be used as part of a low current sense board that I am currently designing. More to come![]()
Eagle Lib: https://www.dropbox.com/s/prj5abe5c8euqu2/GD_TS1100.lbr?dl=0
LT1339
11/30/2015 at 21:08 • 0 commentsPower supplies are easy to buy in certain voltages like 36V or 48V DC. Its a simple case of finding an old server PSU which is rated at 54V and 2500W.
(CISCO WS-CAC-3000W 6500) is a good example £48 for 55A at 42V
Trouble is 42V is a bit high for most applications. The power is useful though so I started to make a high power (~1500W) DC-DC converter to power my brushless motors spindle (Oh so many outstanding projects)
Datasheet: http://cds.linear.com/docs/en/datasheet/1339fas.pdf
Anyway. Here is the library:
https://www.dropbox.com/s/n05o1cr76yy2wio/GD_LT1339.lbr?dl=0
Greg Duckworth
