what happend to the tiny 0404 RGB LEDs?
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
alexAlex • 04/24/2016 at 12:57•0 Comments
I an earlier log I did show a image of these tiny 0404 RGB LEDs. These LEDs were not the right for the footprint I used in this project. But I started I new project with the 0404 LEDs. Pleas take a look at #192:LED. If you want to see what will/could happen to this LEDs And pleas like or follow it.
