1Build an ADC-shield
Use this scheme:
Components for ADC-shield:
- U1-mcp3201, dip-8
- P1 - BNC connector
- P2, P3 - TRG5-5VDC relay
- P4, P5-connector 2.54 mm pitch 13*2 pins
- P6, P7-connector 2.54 mm pitch 5 pins
- P8 - connector 2.54 mm pitch 3 pins
- Q1, Q2 - NPN 2n5551 — 2
- R1, R8-4.7 k, 0.25 W
- R2-5M, 0.25 W
- R3-4M, 0.25 W
- R4-1M, 0.25 W
- R5, R7-820, 0.25 W
- R6-100, 0.25 W
- D1-zener diode 2,4 v
- D2, D3-zener diode 4.7 v
- C1, C4 - 47µF
- C2, C3 - 0.1 µF
- ec11 encoder for arduino x2
If the output of the button on the Board is not pulled up (pull up) resistor, you need to add a 10 kOm resistor:
2Connect SPI display to Orange Pi Zero GPIO
3Download Armbian with legacy kernel for Orange Pi Zero and make loadable sdcard
4Make qt-application
Clone this application: https://gitlab.com/cloud-oscilloscope/qtloscope
Compile it on your computer, load on armblian at sdcard and make it auto-loadable. -
5Create accout at http://oscilloscope.cloud/
6Connect armbian to wifi
7Try to upload data to cloud!
8Check out results
See how your oscillogram displayed on web-interface!
9Well done!
Mikhail Dronov
