Going Solar
07/14/2018 at 21:03 • 0 commentsThese are 1.5 watt solar panels , and I have two for daytime charging. Much better than having to unplug the batteries to bring them in all day to charge then carrying them back out, very practical.
I picked up a couple solar panels to use in charging during the day. Watchdog is low power during the day and shouldn't take much to charge the batteries. 18 watts charge the batteries up from a night of use after about 3-4 hours. So solar charging is within the realm of practically achievable.
recycled cable box for a panda latte/ pi case
03/23/2018 at 17:24 • 0 commentsI have a Latte Panda I am using to dedicate the remote management link to the EZ-Robot micro controller. These use to be discontinued comcast cable boxes. I opened them up using the appropriate star bit screw driver and pulled out the electronics. The logos and such are easy to cover with a simple sharpie and then it is all blacked out but lights like status leds still shine through :)
There should be plenty of room for a raspberry pi board, ac adapter and a hard drive or any memory sticks I would like to use. Stay tunes as I mod it more to have a stylish case for the remote management system.
Cooling the Raspberry PI 3 's
03/22/2018 at 20:03 • 1 commentThe Pi Board before the heat sinks
After applying 5 aluminum heat sinks. I used thermal pad that is similar to a putty to stick them on. the main processor has 4 of the 10 x 10mm heat sinks. the smaller chip which I believe is the ram only has one.
Stormy night runtime test Success!.. Sorta
03/22/2018 at 19:57 • 0 commentsWatchdog will need to run in all weather so I need to know if I can get this guy out in the rain and if there are any significant leaks that I will need to combat. The head is almost sealed and no heat sinks on the raspberry pi so i will check their temps after a night of running without clean airflow. the only additional sealing is a piece of tape around the front hood. I will have a rubber weather seal later when I get a chance and the funds. believe it or not this is a low budget project for what I am making, and that it should be as one of the project goals is sub 1000 dollar build. The second picture is the rear camera on the robot. the raspberry pi that is connected to the front cam keeps failing after a few minutes. I ordered a replacement and in the future I will get heat sinks to make sure 24 hour run time is not a heat issue, after all summer is just around the corner. I may need a fan in there. :\ The Ir leds are running as you can see a purple hue to the white door but otherwise looks ok. You can see that the batteries cause the deck lid to stick up because the head is tilted forward a bit. Maybe I can modify how the body panels mount to compensate for the higher battery type.
Battery Upgrade to Sealed Lead Acid 35 ah
03/22/2018 at 19:46 • 0 commentsLike the title says I am upgrading the batteries. The lawn and garden batteries were actually for my lawn mower robot, because they needed to be charged and discharged quickly and I needed 4 to swap out half way through mowing the lawn. So swapping to the 35 ah batteries would be better, I will start at two batteries but it is looking like they are too tall for the deck lid to go down all the way.. hmmm I will only know after testing that a single 12v battery will be sufficient for a 24 hour tour around the yard recording. At this time in the picture they are wired in 24 volt configuration, but I don't think I need this much voltage. I chose Power Sonic 12 volt 12350 35 ah sealed lead acid batteries.
Testing battery longevity, Lawn and Garden U1-3
03/22/2018 at 19:40 • 0 commentsSo one of my goals is for the robot to operate for 24 hours straight. I started out with cheap 30 dollar Lawn and Garden batteries. U1-3 Advanced auto 340 ca lead acid batteries. Starting voltage is 25.2 in this case for the first test.
End of the test 24 hours later.. Success !! looks like it is totally possible.
Finishing voltage , the gauge still shows all green !
Recycling caster wheels and Hubcaps
03/22/2018 at 19:19 • 0 commentsThe rear wheels are 6 inch casters that have seen better days and are heavily stained. I cleaned them and coated them several times with black rubber to give them a renewed life and also painted the hubs to prevent rusting and remounted them.
I recycled these 4 inch wheel hubcaps from a different wheelchair, whoo I have Rims ! I will spray them to match the body.
Here everything has been assembled again. The rear casters look much better now and have much more grip instead of sliding. The front hubcaps now match like they belong there. :)
Replace velcro mounting with Quick Fasteners
03/22/2018 at 19:14 • 0 commentsFor obvious reasons I removed the Velcro dots and put in some quick fasteners on the mounting tabs. I drilled holes and not I can screw down the deck lid so that someone cannot just pick it up and see the electronics inside. As of now they are Phillips , but I will swap to a security key bolt once things are running smooth.
Gps, Alarm and Power Monitor installation
03/22/2018 at 19:10 • 0 commentsI mentioned earlier I wanted to put in GPS to monitor the robots location, setup a GPS fence and also track it in the event that it is stolen. it has a built in battery and keeps working even after battery is disconnected just like a cell phone. As a matter of fact I can call or text my robot and it will respond and I can hear audio as well!
I took the GPS case apart and installed it upside down so that the connection status lights are not visible, so if it is stolen, the thief wouldn't realize something is still on when the battery is disconnected.
Water resistant battery plugs
03/22/2018 at 19:00 • 0 commentsI am trying out some quick disconnect what are water resistant for the batteries. These are trailer plugs, they have four connections, but I only need two. perhaps I will use the second as a charging circuit? who knows. I will experiment to determine if I like using 24 volts or 12 volts better and then revisit this.
