Lower cost conductivity prob hack
04/11/2018 at 19:07 • 1 commentokay saw a paper on using a hacked USB cable for conductivity prob. Going to try this see if I can get it to work. This would drop cost of adding conductivity to your camera from $215 to $60. Hopefully this works...
Test 178m
04/10/2018 at 19:22 • 0 commentsdid final do a test in Hood Canal by Triton at 178m (584') and it all worked fine. I did upgrade the Lexan from 1/16" to 3/8" just incase. Videos are up on YouTube. Did have a problem with wiring a couple days ago I'm using solid core wires and with pulling this out and putting it in the housing had a wire break from fatigue.
Question how detailed
03/30/2018 at 21:46 • 0 commentsOkay this is my first project. just started writing instructions. How detailed should these be? I'm assuming anyone building this has some experience doing this kind of stuff or should I be more detailed?
Another test
03/22/2018 at 19:48 • 0 commentsWell on 03/20/18 did a test in Case Inlet (80m) for 4hrs all went okay. I'm uploading videos to YouTube now. 17 segments. Once I finish uploading going to go back and add name for all animals. Lots of fish, crabs as well as a 8" nudibranch and a Harbor Seal. Tried to do a test 03/19/18 on Hood Canal but to much wind
