I initially wanted to put all the data in here, in individual logs per display, with a summary table in the details, but then I realized that due to peculiarities of Hackaday we won't be able to edit each other's entries, and it would be a bit difficult to keep track of the changes, etc. Then I realized that this is an ideal use case for a wiki, and decided to just put it all on a wiki on Github: https://github.com/deshipu/displays/wiki
deʃhipu
Splendide_Mendax
SAYANTAN PAL
Andrew Tudoroi
Excellent resource. If you have the inclination and time, it would be nice for the table to include the Vcc and the maximum pin voltages to make it an even more valuable quick reference.
