The Best One Transistor MW Radio Ever
03/22/2018 at 02:08 • 8 commentsThe Best One Transistor MW Radio Ever
Its a bold statement! Can you do better!
It's the 636 One Transistor Reflex:
And a video from the Internet:
Another example:
Here is my simulation of the 636:
A number of changes were made:
- Modified for 9v and crystal ear-piece output.
- Added a 1k base resistor to stop "Colpitts oscillation".
The schematic consists of:
- On the far left, a the signal generator (before the the signal probe).
- Then the short wire antenna model.
- Then the tuning coil and tap at 10%.
- Then the 636 circuit.
Analysis:
- The left analysis is of a 1 mv 1 Mhz signal modulated by a 1 Khz audio signal.
- The audio shows a square law distorted audio output of 6 mv (a gain of x3).
- The right analysis is of a 10 mv 1 Mhz signal modulated by a 1 Khz audio signal.
- The audio shows a square law distorted audio output of 900 mv (a gain of 45).
Replacing the 1 mH inductor with a 1k resistor, reduced the gain by a factor of 3:
Increasing the tuning coil tap to 20% (from 10%) kills the tuning coil Q.
Over to you!
