Even if it’s possible to build everything from scratch, including the rotor (like this, or this), I started from original parts of a Leslie 760, the motor stack (a fast and a slow motor driving the same wheel), the Styrofoam rotor and its assembly.
The control box uses one relay to send power to the slow or the fast
motor, and another relay to send speaker signal to the Leslie speaker or
back to the amp.
Fabien-Chouteau
