Another inefficient design
A project log for Yet Another (Discrete) Clock
I HAD to finally do this basic "exercice de style" in digital electronics, using some hundreds of transistors and diodes...
yann-guidon-ygdesYann Guidon / YGDES • 02/17/2016 at 02:26•0 Comments
I just came across this circuit/diagram:
https://en.wikipedia.org/wiki/File:D-Type_Flip-flop_Diagram.svg
Using complementary logic, it uses 36 transistors... that's 20 transistors more than the circuit I came up with in the precedent log.
OTOH it does not use a single resistor.
