Available to buy at TINDIE store! https://www.tindie.com/products/marjan_mike/solder-paste-or-liquid-dispenser-5v-dc-usb-no-air/
Dispenser V4 and V5 tests
Posted by Applecture.com
Electronic 5V DC powered Solder paste Dispenser AIR FREE / AIR LESS operation V2. The goal to build this Dispenser was to be as cheep as possible and to avoid using any 3D printed parts! … Continue reading
MikeM
hello3dprintingworld
Marc Schömann
Chleba
CodeMonkeyHacks
What is the smallest needle (mm inner diameter ) that you an use for solder type Type 6 that the stepper motor and its gear can pressure without leakage in the syringer .
LH4PI
