Solder Paste Dispenser V6 - AIR FREE & 5V USB-NEW!
DISPENSER V6 for Manual solder Paste application (without compressed air) to PCB for reflow soldering or Hot-Air
Soldering techniques.
Public Chat
The goal to build this Dispenser was using 5V USB & NO COMPRESSED AIR and to avoid using any 3D printed parts, to be reliable and safe for use by hobby guys and schools to use for low volume of PCBs SMD SMT parts soldering with hot air, on hot plate, or in reflow owen. Dispenser V6a was out on Tindie in May 2020 (see hystory and NEW LOOK http://wordpress.mencinger.biz ) – syringe volume of dispenser is 10cc to 12 cc ( industrial syringe is in scope of supply). Joystick controls turns of stepper motor shaft left or right and move piston in syringe in chosen direction and force the paste (or liquid) in syringe to move out through needle.Dispenser has a built in very powerful stepper motor with full metal gear gearbox witch with tremendous pressure forces paste (or liquid) out of the syringe.
More Details:
Available to buy at TINDIE store! https://www.tindie.com/products/marjan_mike/solder-paste-or-liquid-dispenser-5v-dc-usb-no-air/
Dispenser V4 and V5 tests
Posted by Applecture.com
Electronic 5V DC powered Solder paste Dispenser AIR FREE / AIR LESS operation V2. The goal to build this Dispenser was to be as cheep as possible and to avoid using any 3D printed parts! … Continue reading
JPEG Image - 178.25 kB - 06/16/2016 at 03:25
Preview
JPEG Image - 85.36 kB - 06/16/2016 at 03:25
Preview
JPEG Image - 121.62 kB - 06/16/2016 at 03:25
Preview
JPEG Image - 129.80 kB - 06/16/2016 at 03:25
Preview
JPEG Image - 100.66 kB - 02/20/2016 at 09:49
Preview
View all 6 files
  • 1 × Main PCB with electronic parts and stepper motor
  • 1 × Syringe 10ml with LOCK needle output neck,
  • 1 × 3 way Luer Lock Valve
  • 2 × Stop Plug-Cap
  • 9 × plastic needles
View all 6 components
View all 3 project logs
View all instructions
Lars Herrnsdorf wrote 03/01/2021 at 13:38 point
What is the smallest needle  (mm inner diameter ) that you an use for solder type  Type 6  that the stepper motor and its gear can pressure without leakage in the syringer .
LH4PI
MikeM wrote 06/29/2020 at 09:45 point
I have some 2020_ V6a avalible on Tindie now - limited stock - with 3D printed Syringe holder...
Mike
Arno Moonen wrote 01/06/2018 at 22:20 point
Are these still for sale?
MikeM wrote 06/29/2020 at 09:42 point
I have some V6a avalible on Tindie - with 3D printed Syringe holder...
Mike
MikeM wrote 12/07/2016 at 09:14 point
Hello dwHacks,
This model will not be available no more - I stream into improvements from feedback and I work new version which will be out in 2017...
Tindie store is not closed but all dispensers are sold out and there is nothing to show at the moment. Keep your monitoring:
-http://wordpress.mencinger.biz/v6-dispenser-development/
-https://mencinger.biz/news.html
and have a nice day!
Mike
dwHacks wrote 12/11/2016 at 18:45 point
thank you! Looking forward to it!
dwHacks wrote 12/06/2016 at 18:31 point
is this going to be back in stock any time soon? Or back on tindie? It seems your tindie store no longer exists.
andyl wrote 04/07/2016 at 16:25 point
I'm using Mike's dispenser - great device and great support.
MikeM wrote 02/04/2016 at 22:46 point
Use Google - may help !
MikeM wrote 02/02/2016 at 17:15 point
This is the analog joystick replacement from PSP2000 PSP 2000 PSP2000 Slim.Comes with the thumb button.
there are others as well - http://www.dx.com/p/replacement-analog-stick-joystick-for-playstation-vita-black-199587#.VrDjudLhAdU , .............
James Newton wrote 02/01/2016 at 18:12 point
I'm trying to understand the feed system. How do you refill the syringe? More specifically, how do you retract the plunger? And how far can the plunger be retracted or in other words, how much paste can you actually load... are you able to fully load the syringe, or just half load it, or...?
MikeM wrote 02/01/2016 at 18:41 point
see my YouTube channel for your answers
MikeM wrote 01/31/2016 at 19:46 point
follow this link here zakqwy http://wordpress.mencinger.biz/?page_id=61
or search on eBay Dispenser for Solder Paste V3 or contact me directly mike.menci (at) gmail.com
zakqwy wrote 01/31/2016 at 23:29 point
Do you sell _just the joystick_ separately? It's got the Trackpoint-style nub on it--is it actually an analog pointing stick, or just a 4-way joystick with a cap?
zakqwy wrote 01/31/2016 at 18:34 point
That looks like a Trackpoint! Where did you find one for sale?
