Version 2.7.0 released
11/14/2017 at 19:10 • 0 commentsGet your update OTA today!
Optimized pitmaster and a couple of bugfixes.
Enjoy!
Cheers
Armin
New Release 2.5.2-0 Bilingual DE_EN
12/02/2016 at 18:37 • 0 commentsHi friends,
the latest release supports English and German user interface!
We also incorporated Celsius/Fahrenheit-Switch and lots of other fixes and improvements.
In case of a failure of the online-update, please ssh to your decvice and do the following:
wget https://github.com/WLANThermo/WLANThermo_v2/raw/master/ressources/fix_installation.sh sudo bash ./fix_installation.sh
After that, you can access webinterface and perform a normal update.
Changelog since last projectlog:
wlanthermo (2.5.2-0) stable; urgency=medium * FIX: start update as an extra service -- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Tue, 29 Nov 2016 22:30:00 +0100 wlanthermo (2.5.1-0) stable; urgency=medium * FIX: added missing probe documentation * FIX: Pitmaster: Reversed fan control doesn´t work * FIX: max and min alerts weren´t handled as float * FIX: display stops working on special chars in channel name * FIX: wrong names in probe reports * FIX: restore broken updates * CHANGE: remove superfluous decimals from values -- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Tue, 29 Nov 2016 08:44:00 +0100 wlanthermo (2.5.0-0) stable; urgency=medium * CHANGE: changed startup from SysV-init to systemd units * CHANGE: moved sudoers entries to seperate file * CHANGE: i18n of the source code * CHANGE: new display HMI version with icons * CHANGE: split alert messages to push/ telegram/ app * CHANGE: changed valid adc values from x > 60 to 15 < x < 4080 * CHANGE: Nextion HMI Version 2.0 * FIX: Poweroff on shutdown * FIX: Handle configuration file as UTF-8 * ADD: probe documentation in Markdown format * ADD: function to recalibrate the NEXTION touchscreen * ADD: translation to english * ADD: temperature unit selectable between celsius and fahrenheit * ADD: probe type iGrill2 * ADD: probe type ThermoWorks * ADD: probe type ET-73 * ADD: probe type Perfektion * ADD: probe type ET-735 * ADD: probe type ODC * ADD: probe type Santos * ADD: probe type SmokeMAX * ADD: probe type Weber_6743 -- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Mon, 21 Nov 2016 14:10:00 +0100 wlanthermo (2.4.0-0) stable; urgency=medium * ADD: WLAN Reconnect über HMI * ADD: °C hinter den Temperaturen auf dem Display * ADD: Senden einer Testnachricht * ADD: Senden einer Pushnachricht * ADD: Solltemperatur mitloggen * ADD: Größere Plotgrößen * ADD: ZeroConf Dienstekonfiguration * FIX: GPL-Info in info.php * FIX: Neue configeinträge wurden nicht uebernommen * FIX: Shutdown der V3 über Button funktioniert nicht * FIX: Display - Sleepmodus bei Shutdown über Web-GUI * FIX: pit_man wurde nicht ausgewertet * FIX: HMI Version 1.8 * FIX: Datenübertragung Display nach Wakeup korrigiert * FIX: PID Regelalgorithmus verbessert * FIX: Fehler bei KTYPE an Hardware > v1 behoben * FIX: Umlaute im Kanalnamen werden angezeigt * FIX: Neue Sensorparameter * FIX: Nextion-Display reagiert nicht korrekt auf Shutdown * FIX: Upload für Nextion-Display an neue Firmware angepasst * CHANGE: Medianfilter angepasst * CHANGE: Schleifenzeit der Messchleife korrigiert * CHANGE: Auslesen der Konfiguration in der Messchleife * CHANGE: Pitmaster: Anti-Windup II implementiert * CHANGE: Mehr Sonderzeichen und längere Passphraser für WLAN-Passphrase * CHANGE: Energiesparmodus für WLAN-Adapter deaktiviert * CHANGE: Nextion-Display per Default konfiguriert und aktiviert -- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Sat, 16 July 2016 14:45:00 +0200
Enjoy!
Cheers
Armin
New Release 2.3.1-1 available
02/28/2016 at 08:41 • 0 commentsDear friends and followers of WLANThermo (which should be named WIFIThermo in the english world but we are Germans, you know... :D),
We proudly announce the release of the new version 2.3.1-0 after many long days and nights of coding, debugging, testing, building and beerdrinking. Ok, the proud got damped a bit after we realized, 2.3.1-0 had a glitch in the final building-process! So we spent another long saturday in debugging, coding, testing, building (well and coffee this time ) and last night, we made it and released the hopefully working 2.3.1-1!
Our focus with this release was adding some features, fixing bugs and increasing usability.
Here is a translation of the original changelogs:
Changelog 2.3.1-0 ADD: Alarm quittieren ueber das Display Acknowledge Alams with touchscreen ADD: Nextion Display ueber Terminal flashen möglich Flash firmware of display via terminal ADD: Ordner /var/www/conf ist jetzt im geschuetzten Bereich Put configuration file in password-protected area ADD: Softwarelizenz GPL Include GPL ADD: Pitmaster Solltemperatureingabe jetzt mit einer Nachkommastelle (Armin's Onseneifunktion) Pitmastertemperature now with 1 decimal place (i skip the Osenegg-portion) ADD: GPIO fuer IO und IOPWM waehlbar zwischen GPIO4 (12V Signal) und GPIO2 (3,3V Signal) Selectable GPIO for IO and IOPWM (result:switchable IO-Signal from 3,3V to 12V) ADD: GUI-Update gibt Informationen ueber den laufenden Installationsstatus aus Updateinformation in GUI during onlineupdate - Not just wait but you can see, what Raspi is doing ADD: Zero Cut Funktion fuer Luefter Zero cut function for fan FIX: IP Adresse wird in der wifi.php nicht angezeigt No IP-Adress shown in GUI FIX: index.php Webcambilder werden nicht angezeigt/ imagemagick wird Installiert (Fehlt unter Jessie) Missing webcam-pictures FIX: Display-Update V1.0, Neue Tastaturen, Sonderzeichen, Alarmquittierung, Fehlerbereinigung, Speicheroptimierung Nextion Display Firmwar version 1.o, new keyboards, FIX: Herunterfahren und Neustart mittels Display funktioniert Restart and shotdown via Display works now FIX: Es lassen sich jetzt mehrere WLANS ueber das Display konfigurieren Configure multiple accesspoints with touchscreen FIX: WIFI Script language.d Problem geloest. language problem solved in wifi-script FIX: Info Seite angepasst changed info-page FIX: Pitmaster beim Neustart pitmasterproblem (always on) after restart FIX: Duty Cycle min bei IOPWM minimum dutycycle. Changelog 2.3.1-1 FIX: GUI-Update gibt Informationen ueber den laufenden Installationsstatus aus Now really info during update FIX: Fehler in der function.php - Neue configeinträge wurden nicht uebernommen missing values in configuration FIX: Fehlerhafte Versionskennzeichnung in der header.php behoben wrong version-encoding FIX: DOS-Umbrüche in /usr/bin/raspiwebcam.sh beseitigt windows formatting of a shellscript
Update is available via onlineupdate. If you build a new thermometer, just download the software as described in the documentation and you will be on 2.3.1-1!
I hope you enjoy it and feedback is always welcome!
Cheers
Armin
3D-printerfiles for mini-case
02/17/2016 at 15:26 • 0 commentsGood news: the files for 3D-printable cases are available on github now!
https://github.com/WLANThermo/WLANThermo_Hardware/tree/master/mini/case
New Release 2.3.1-0 under development
02/14/2016 at 19:31 • 0 commentsA new release is under development and testing.
Mostly bugfixes and GUI usability
add: show CPU-temperature
improve: wireless menu
and a bit more
To be released soon!
