Done! (With the Layout) ...almost.
A project log for piStudio
Portable recording studio.
daniel-fraustoDaniel Frausto • 03/14/2016 at 05:53•0 Comments
Well I separated all panels. All unnecessary parts where removed... if you can tell i did not add the USB port because i am planning on having them mounted on aluminum panel... then than panel will be added .Check it out. Files are in the Download Section Named OnlyCase.
