Exporting the paths....
A project log for piStudio
Portable recording studio.
daniel-fraustoDaniel Frausto • 03/14/2016 at 06:21•0 Comments
Now I have Finished exporting the paths to a dxf file that will be used in a Cam program to create the cnc paths( G-Code ) to be used to route out the case from the material...likely to be acrylic. take a look.
If you want to check it out, the *.DXF will be in the Download Section... it's uploading as we speak....
UPDATE: HERE IT IS.
