More update videos
03/02/2016 at 23:17 • 0 commentsDidn't actually take the hubs off in the end - removed the whole subframe instead
Removed the whole subframe by unbolting the shock top mounts, subframe bolts and control arms
Took the engine out by dropping it on the floor using an engine hoist, then lifting the car body off by the engine mounts, and dragging the engine out from underneath
Began dismantling the engine - need to inspect the crank to find any damaged bearings
Explaining the removal
03/02/2016 at 23:11 • 0 commentsJust a brief video explaining the plan
Disconnecting engine
02/07/2016 at 02:20 • 0 commentsThe first step to removing any engine is to label things up and disconnect every hose, cable, wire and driveshaft from the engine.
This is the start of that process
