Wow! So much opportunity!
02/08/2016 at 06:47 • 0 commentsEither way, when this contest is over, I need to get in touch with some of the entrants. I've already seen 2 things that could be stacked on my leaves...
Design the Case
02/08/2016 at 06:29 • 2 commentsLast night, I designed my case using a combination of Sketchup, and XYZWare (beta).
I am forced to use XYZWare because I received one of the Davinci Jrs for Christmas (and I'll definitely be using it to build another printer, but one that is not DRM'ed)
I learned very quickly that XYZWare is not quite ready for primetime, so I wound up designing in Sketchup, then using the STL export, so that I could open the STL in XYZWare to save in a format that would not get trashed by the printer firmware (SOOOoo many issues grabbing anything from outside of XYZPrinting's universe)
I decided to save everything in 2 formats: STL and 3w (proprietary for XYZ)
The STLs can be found on Thingiverse: My first Design
