« Back to project details
VB.Net Software
07/12/2016 at 21:18 • 0 comments -
The FirmWare...
07/12/2016 at 21:08 • 0 commentsThis FirmWare got things going...
// set pin numbers: const int sw2 = 2; // Down limit const int sw3 = 3; // Up Limit const int ledPin = 13; // Pwr L.E.D const int ic1_2 = 8; // TA8409S IN2 const int ic1_1 = 9; // TA8409S IN1 const int enable = 10; // TA8409S Enable (motor) boolean sw2State = HIGH; // Down Limit State boolean sw3State = HIGH; // Up Limit State void setup() { Serial.begin(9600); // Setting L.E.D and Motor In, Enable pins as an output: pinMode(ic1_1, OUTPUT); pinMode(ic1_2, OUTPUT); pinMode(enable, OUTPUT); pinMode(ledPin, OUTPUT); // Setting limit switches pins as inputs pinMode(sw2, INPUT_PULLUP); pinMode(sw3, INPUT_PULLUP); // Enables motor digitalWrite(enable, 1); //Starts program down down(); } void loop() { // reads the state of the limit switches //Serial.print("Reading SW2 State\n"); sw2State = digitalRead(sw2); //Serial.print("Reading SW3 State\n"); sw3State = digitalRead(sw3); if(debounce_sw3(sw3State) == LOW && sw3State == HIGH) { Serial.println("Up Limit Reached\n Going Down\n"); down(); sw3State = LOW; } if(debounce_sw2(sw2State) == LOW && sw2State == HIGH) { Serial.println("Down Limit Reached\n Going Up\n"); up(); sw2State = LOW; } boolean debounce_sw2(boolean state) { boolean stateNow = digitalRead(sw2); if(state!=stateNow) { delay(10); stateNow = digitalRead(sw2); } return stateNow; } boolean debounce_sw3(boolean state) { boolean stateNow = digitalRead(sw3); if(state!=stateNow) { delay(10); stateNow = digitalRead(sw3); } return stateNow; } void up() { Serial.println("Up started\n"); digitalWrite(ic1_1, LOW); digitalWrite(ic1_2, HIGH); } void down() { Serial.println("Down started\n"); digitalWrite(ic1_1, HIGH); digitalWrite(ic1_2, LOW); } void err() { digitalWrite(enable, LOW); digitalWrite(ic1_1, LOW); digitalWrite(ic1_2, LOW); }
This code is messy...
02/08/2016 at 11:28 • 0 commentsI have been trying to write code that makes sense. all it is now is if and while statements....
