RPiHeatingOilSensor.zipThe Oil Sensor (433mhz version & TCP versions).Component List: HC-SR04 Ultrasonic Sensor DS18B20 Thermometer Headers (male and female) DuPont Connectors Various Wiring Component List for 433mhz Version: Arduino Pro-Mini RXB6 433Mhz SuperHet Receiver FS1000A 433Mhz Transmitter ZS-042 (DS3231) RTC Component List for TCP version ESP8266-ESP (07 or 12) 2x 3mm*4mm momentary switch 6x 10K (0806)resistors 1x 6.8K (0806) resistor 1x 3.3K (0806) resistor 1x 2n7000 mosfet 2x 10uF/106 (0806) capacitor 1x 100nf/104 (0806) capacitor 1x 1000uf electrolytic capacitor 1x AMS1117 3.3v 1x LM7805 1x 10uf electrolytic capacitor 1x 1uf electrolytic capacitor 1x 100K 1/4 watt resistor 1x 6.8K 1/4 watt resistor PCB for etching Zip Archive - 164.33 kB - 05/27/2016 at 10:54 |
RPiHeatingInstall.zipBeta version for Raspbian Jessie. Should work on most SPI based touch screens. Make sure to set up Jessie for your touchscreen and take note of pins needed.sudo raspi-config Select Advanced -> A3-Memory Split -> 16 Select Advanced -> Device Tree -> Yes Download zip and place in /home/pi/ unzip RPiHeatingInstall.zip sudo bash /home/pi/RPiHeatingInstall/setup.py follow instructions. Component list: LED red x 1 LED green x 1 SPI touchscreen (this is mine https://www.raspberrypi.org/forums/viewtopic.php?f=64&t=48967 but should work with most SPI based touch screens) Wifi adapter/ethernet cable 5v Relay Module SD Card (4gb + should do) Wires dupont connectors 433mhz receiver + transmitter (optional) Zip Archive - 184.75 kB - 05/27/2016 at 10:41 |
Sources.mdList of sources for code and librariesmd - 2.70 kB - 04/25/2016 at 10:58 |
Licence.txtGPL v3.0plain - 34.98 kB - 04/25/2016 at 10:58 |
