1Step 1
Get a Raspberry Pi, SD card, webcam and other necessary hardware (see components list). You can ignore the additional components needed only for development.
2Step 2
Download the light version of Raspbian from the download page of the raspberry.org website.
3Step 3
Create a bootable SD card from the downloaded image.
4Step 4
Boot up the Raspberry Pi and connect to it using the USB-TTY serial cable, and temporarily plug in a WiFi dongle or USB ethernet connector into the USB port.
5Step 5
Log into the Pi (using the default "pi" user). Use "raspi-config" and perform the initial Pi setup (expanding the OS to use all of the space on the SD card etc.). Reboot the Pi.
6Step 6
Configure the network settings for your ethernet or WiFi network and reboot the Pi.
7Step 7
Update the default Raspbian components using "sudo apt-get update".
8Step 8
Download and install the "fswebcam" software by entering "sudo apt-get install fswebcam".
9Step 9
Download and install the OCR software by entering the following commands:
- sudo apt-get install tesseract-ocr
- sudo apt-get install tesseract-ocr-eng
You can install support for additional languages by repeating the last command, changing the "-eng" suffix into another ISO 639 language code (not all languages are supported though).
10Step 10
Download and install the text-to-speech software using the command:
- sudo apt-get install festival
Markus Dieterle
