Project is not complete.
04/27/2016 at 19:27 • 0 commentsI am moving into a new method for unzipping into graphene oxide nano ribbons via a stepwise hummers method.
In order to avoid destroying the massive aspect ratio of MWCNT when unzipping I will be doing thing's a little different than the standard of making graphene oxide.
eh ill update this tonight I want to go start
This project is complete
03/22/2016 at 00:22 • 0 commentsI have sucessfully synthsized GNR not because I have an SEM to quantify them but because my anode material for K/S/SiO2 and Li/S/SiO2 is now conductive where as nothing worked before.
At over 65% by weight SiO2 when first wrapped with GNR and then carbon black added I am getting around 150,000 ohms resistance where as the previous versions were completely insulating.
When I add just 3 % copper 300 mesh powder the resistance drops to 2 ohms which is very exciting meaning I can actually print battery anodes and have them work without charge collectors.
MECHANICUS
