boom, starblinken kit is on tindie!
09/06/2018 at 09:34 • 0 commentsI've tested and verified my design and put it on tindie btw. :)
--End of Advertisement--
https://www.tindie.com/products/davedarko/starblinken-diy-kit/
here's a little video
07/29/2018 at 14:23 • 0 comments -
verified the board design
07/22/2018 at 14:34 • 0 commentsI hand wired a combo of NE555, CD4017 and two ULN2003 chips. I also spray painted the protoboard before that. The capacitor I chose is a bit too small, so the animation is a bit too fast. I'll need to grab a 2uF instead of a 1uF cap. Definitely need to add a 100nF cap for the 555 and maybe some more all around.
here's a link to it working:
https://www.instagram.com/p/BliYSjGDVXg/?taken-by=davedarkocom
working on a star blinken thing
07/20/2018 at 07:10 • 0 commentsfinally came back to this :)
RGBY LEDs
05/14/2017 at 09:55 • 0 commentshttp://www.ebay.de/itm/172664995172
I've ordered some of CNLohr's RGBY LEDs for my WeMos shield, will update this once they arrive :)
HT16K33 board arrived
05/11/2017 at 19:09 • 1 commentBoard works :)
HT16K33 board for 11x7 LED matrix
04/15/2017 at 16:04 • 5 commentsI recently bought a cool 11x7 matrix, that is just great to display 4 3x5 digits and I want to control it with the well supported HT16K33 - so here's a not so beautiful and highly convoluted board for that.
2nd try - this time with SK6812 LEDs
03/03/2017 at 17:51 • 0 commentsDefinitely mooooaaar white :)
Got scammed on aliexpress? meh
03/01/2017 at 11:40 • 7 commentsSo I thought I've bought the new SK6812 with RGBNW on aliexpress.com, but instead I received some standard RGB WS2812 LEDs - not cool :( but the shield works. Now I've bought half of the LEDs for the same price on eBay, let's see how that will turn out ;) dispute on aliexpress was opened, hoping for at least some refund.
3 little boards - blinky stuff
02/10/2017 at 19:37 • 2 commentsWemos 2812B moaaaar LEDs shield
After seeing RGBW LEDs on the Adafruit stream I quickly went on Aliexpress to buy some and then designed a Wemos D1 shield for them, just not with only one LED.
SMD LED bargraph for breadboards (with Resistors)
A classic, but I was in the mood to design it.
RGB LEDs charlie-plexed pinout
This is basically the layout of one column of a 4x4x4 RGB LED cube...
davedarko
