imu_test_v2.inoArduino for K9 Controller (v2 with Madgwick filtering) per https://github.com/arduino-libraries/MadgwickAHRS/Updated version, does not send data via xbee until a (any) button is pressed to ensure minimal running when charging via induction ino - 7.96 kB - 04/04/2016 at 07:09 |
K9.pdfK9 Prop diagram that is usually used for external panels/shell creation. Im going to lean towards using the majority the same way except for maybe the bottom panels in the body which do come in a fair bit reducing the amount of interior room for the motorsAdobe Portable Document Format - 74.82 kB - 03/26/2016 at 10:05 |
nes_switch_holder v3.stlFile for mounting the 7mm on off push button switch in the NES controllerStandard Tesselated Geometry - 3.79 kB - 03/11/2016 at 07:51 |
nes controller button cap v2.stlButton cap for the switch (requires fine printer or some 'modifying')Standard Tesselated Geometry - 5.94 kB - 03/11/2016 at 07:51 |
K9Controller_Gerber_Files.rarGerber files for custom PCB for NES controller buttons to tie to Arduino FIORAR Archive - 63.04 kB - 03/05/2016 at 01:50 |
Andrew Bills
