• Branch Correction Correction
    Reed Foster • 03/26/2016 at 16:34 • 0 comments
    Debugging
    As I was running some test code, I discovered that stale register data was being used to execute the jump register instruction. The fix for this was simple; I added a "new $s" signal from the forwarding registers to the branch correction. In addition, I also tidied up and simplified the branch correction.
    Old Branch Correction
    New Branch Correction
    This simplified design is not only easier to understand, but it is also faster because there is no longer a chain of multiplexers that the "PCNext" signal has to propagate through.
