lambdaCPU v4.circ
Processor file, requires installation of logism to work.
412.75 kB -
07/10/2016 at 03:54
Download
lambdaCPU instructionset.xlsx
I used this to design the instruction decoder, useful if you want to write code
sheet -
10.28 kB -
02/21/2016 at 21:34
Download
lambdaCPU code.txt
Notes for code (for reference only, may have errors, so if you want to run one of the programs, load it from the looptest.txt or hilotest.txt files)
plain -
1.32 kB -
02/21/2016 at 21:18
Download
lambdaCPU looptest.txt
Code that tests the branch prediction (only backwards); right click on ROM labeled "program" in logisim, select load image, and choose this file to run the program. To change value that code counts to, change the lower two bytes of the first instruction to the desired value.
plain -
52.00 bytes -
02/21/2016 at 21:16
Download
lambdaCPU hilotest.txt
Code that tests the accumulator registers; right click on ROM labeled "program" in logisim, select load image, and choose this file to run the program.
plain -
102.00 bytes -
02/21/2016 at 21:15
Download
lambdaCPU v3.circ
Old version, branch prediction/execution does not work properly because of forwarding. Processor file, requires installation of logism to work
circ -
414.98 kB -
02/21/2016 at 21:37
Download
